14 years agoI want to use different oscillator
Hi I am using MAX II Micro Kit. In my application i need to use 32.768Mhz oscillator. Can i replace 50 Mhz oscillator with 32.768 Mhz? If i change it, will i have programming problems? how ca...
14 years agoI've never seen 32.768MHz oscillator, but if You found one, then there should be no problems. Check twice if it is not 32768kHz
