17 years agoI want knowing POF file format structures.
hello, everyone.
I want knowing POF file format structures. I can open a .pof file and program this to the EPCS16 device if i know the length of the header so i can remove it first. The header includes info about Quartus build date/version/device/comment e.t.c The .pof file also includes a signature, but since the useful data only exists until about 1/3 into the file, this signature is also removed when programming.. Does anyone know the .pof file format? I really need to know this: 1. Where is the header-length is specified? 2. What does the different "unknown" bytes in the header (except for the obvious ascii coded strings) specify? My application can also read the contens of the flash and save it to a file. It would be really useful if this could be saved in a .pof valid format, and written back using the quartus programming tool, so: 3. What does the Quartus programming tool look for to determine if the .pof is valid? (checksum? probably some of the info requested in 1, 2?) 4. What does the signature/footer describe? Thanks so much.15 Replies
i am researching those data,
thanks very much - Altera_Forum
thank you, vernmid.
I wish changing like that. But,the b/d developer does not want the rbf format.:o - Altera_Forum
Have you considered a different file format?
rbf for example http://www.altera.com/support/kdb/solutions/rd01212004_4844.html Just contains the data - Altera_Forum
thank you, batfink.
I don't think Altera publish the pof file format. You could try asking them via "My Support" though.
