YYoreh
7 years agoI think there is a bug using EPCQ to program CYCLONE V with a compressed *.sof file
I am using an EPCQ128 device to load configuration data to my 5CEFA7F23C8N device. When i create a *.jic file, i check "compress" in the file properties. During the programming (Quartus Programmer), ...
- 7 years ago
I use a compressed .jic file for my Cyclone V programming (EPCQ128). Here's what I found, I don't know if it will help you or not. When you create the .jic programming file, select EPCS (not EPCQ) as your programming device. This works for me, otherwise it fails as you describe.
GLees
Contributor
7 years agoI use a compressed .jic file for my Cyclone V programming (EPCQ128). Here's what I found, I don't know if it will help you or not. When you create the .jic programming file, select EPCS (not EPCQ) as your programming device. This works for me, otherwise it fails as you describe.
