I_PIN_PERST_N signal is not assignable in Agilex 7
- 3 years ago
In the Pin Planner, I try to assign pin Y21 as the PERST_N signal, but I get a message that the pin is not assignable.
>> if you assign the pin based on the example design, did you see any error ?
>> is there any specific reason you change the pin location ?
But if I don't assign the pin, I get the following Critical Warning: "There is no accurate pin location assignment(s) for 1 of the 693 total pins. To see the pin list, refer to the I/O assignment warnings table in the installer report."
>> According to the user guide , If the F-tile is unused, or the F-tile is used but PCI Express* is unused, tie to GND.
>> Did you try to Use a level translator to fan out and change the 3.3-V open-drain nPERST signal from the PCIe* connector to the 1.8-V input of each F-tile transceiver that is used on the board. Provide a 1.8-V pull-up resistor for this input pin as the nPERST signal from the PCIe* connector is an open-drain signal. You must pull up the 3.3-V PCIe* nPERST signal on the adapter card.
>> PERST# should be connected between the host slot and our device as shown in our dev kit schematic:
Wincent_Intel
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
Else I would like to have your permission to close this forum ticket
Wincent_Intel
- Finees3 years ago
Hi
Sorry for delay. It was useful the information that you provided me. I provided a 1.8V pull-up resistor in the pin perst_n.I have no further questions.
Thank you
