zlan01
6 years agoI instantiaze a pll with 4 output clock,but when I use Derive PLL Clocks command in Timing Analyzer, it only derive two generated clock?
altpll1 altpll1_inst ( .inclk0 ( chip_clk ),//20Mhz .c0 ( sys_clk ), //400Mhz .c1 ( uart_clk ), //25Mhz .c2 ( clk_50M ), //50Mhz .c3 ( clk_30M ),//30Mhz .locked ( locked_sig ...
Rahul_S_Intel1
6 years agoHi ,
When I made a simple PLL and try to put the list fro the name finder , I can see all the out put from the PLL . May I know is that is a problem for you . The same is not view by you
Rahul S
