AKent1's avatar
AKent1
7 years ago
I have some questions regarding SPI code implementation with nios ii .
  • Ahmed_H_Intel1's avatar
    Ahmed_H_Intel1
    You are welcome,
    Please let me know if you need more support.
  • AKent1's avatar
    AKent1
    Yes thanks for the links.. I get it. Looking over stuff it appears that alt_avalon_spi_command is of very limited capability
    and that I will have to delve into IO.h "primitives"
    I was puzzled on the documentation for it.
  • AKent1's avatar
    AKent1
    I am a novice fpga programmer forced to do firmware so I am not super knowledgeable. I successfully was able to create a nios embedded system with SPI, and am using the alt_avalon_spi_command
    Now in reading the documentation, it says that it writes a buffer to mosi of arbitrary length but in the same breath it says that it only works for 8 bit data widths.
    I am looking at the output with signal tap and it seems to indeed be limited to 8 bits.
    Is this correct?
