MSchu8
7 years agoI have an existing design which uses Active Serial Configuration via an EPCQ128. After migrating to the EPCQ128A, I am having problems with remote updating.
I have an existing design which uses Active Serial Configuration via an EPCQ128. The design also has remote update capability. The mechanism for the remote update is to put the update into a separate...
ShafiqY_Intel
7 years agoHi MSchu18,
If your design do not contain IP Cores (which interface with the configuration device), your existing programming files may be compatible with EPCQ-A devices without the need to regenerate the programming files. Refer to Table 3 on page 6 for more details.
If you design contain IP core, please refer to Table 1 & Table 2 (on page 5) for the IP core compatibility.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an822.pdf
I hope this will help.
