OBENN2
7 years agoI have a question on a FPGA P/N EP1C20F324C7 I want the signal DATADIR to go to gnd. Do I connect it directly to ground or do I Contact it to ground through a resister, and if I use a resistor what value should it be?
SreekumarR_G_Intel
7 years agoCyclone FPGA IO can directly connect the pin to the Ground. But it is recommended to connect through resistor to protect from accidentally driving a pin as output.
Please refer the below link for Cyclone handbook Table 4–3. Cyclone Device DC Operating Conditions ,
https://media.digikey.com/pdf/Data%20Sheets/Altera%20PDFs/Cyclone_FPGA_Family.pdf
There is also feature in Intel FPGA called , " Bus hold " You can refer in section in handbook.External pull-up or pull-down resistor is not necessary to hold a signal level when the bus is tri-stated.
Note: The bus-hold circuitry is only active after configuration,whereas external resistor are active before and during configuration.
