jmelv
7 years agoI have a problem on the Cyclone V with CVP failing with a CVP_CONFIG_ERROR error on the second update cycle.
I can initialize the core image after power on and I can update it once. The next update fails with a CVP_CONFIG_ERROR. The only way to clear the problem is to reboot. The Cyclone V GT development ...
JohnT_Altera
7 years agoHi,
If you are using CVP Initialization only then you will not be able to performed second core update. In order to performed subsequent core update then you will need to enable the CVP Update features. Without this then you will not be able to performed subsequent CORE update. Please be aware that subsequent core update will not support Gen 2.
