jmelv
7 years agoI have a problem on the Cyclone V with CVP failing with a CVP_CONFIG_ERROR error on the second update cycle.
I can initialize the core image after power on and I can update it once. The next update fails with a CVP_CONFIG_ERROR. The only way to clear the problem is to reboot. The Cyclone V GT development ...
jmelv
7 years agoHi John,
I am not using CVP update mode, I am using CVP Initialization mode and doing a core image update. The CVP initialization works, so does the first core update. I know the link is set to Gen2 on the first core update since I can operate the board at the Gen2 rate before and after I do the update. It's the second core update that fails but nothing leading up to that update is different than the first one. The documentation says I should be able to update the core image without having to reboot.
