jmelv
7 years agoI have a problem on the Cyclone V with CVP failing with a CVP_CONFIG_ERROR error on the second update cycle.
I can initialize the core image after power on and I can update it once. The next update fails with a CVP_CONFIG_ERROR. The only way to clear the problem is to reboot. The Cyclone V GT development ...
JohnT_Altera
7 years agoHi,
May I know if you are using Gen 2 when performing CvP update? The reason is that Cyclone V does not support CvP update using PCIe Gen 2. Could you try to lower down it to PCIe Gen1 when performing CvP?
You may refer to https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/fb125216_cv.html.
