jmelv
7 years agoI have a problem on the Cyclone V with CVP failing with a CVP_CONFIG_ERROR error on the second update cycle.
I can initialize the core image after power on and I can update it once. The next update fails with a CVP_CONFIG_ERROR. The only way to clear the problem is to reboot. The Cyclone V GT development ...
jmelv
7 years agoYes, on the core image. The same software function is called each time. This is a PCIe x4 Gen 2 board using a flash device to configure the periphery at power up then loading a .rbf file for initialization and update. The first and second load of the core always works, the third always fails. The flash and the rbf file are not compressed or encrypted.
