10 years agoI get message error when trying to install devices in quartusII
I get this message: There has been an error.
Unknown element arria10_part1. the application will exit now. Anyone know why? Please Help16 Replies
Hi parapapap,
Thanks for the sharing on the patch. - Altera_Forum
--- Quote Start --- That's great! Good luck with your project:) --- Quote End --- Thanks a lot - Altera_Forum
--- Quote Start --- That's great! Good luck with your project:) --- Quote End --- Hello parapapap, now I have the next problem: "Problem Details Error: Internal Error: Sub-system: DEV, File: /quartus/ddb/dev/dev_family_info_mgr_body.cpp, Line: 287 Failed obtaining data for part 5CGXFC9E6F35I8SD" I hope you can help me to solve please. Cheers! - Altera_Forum
Hi Wen,
This is a QII internal error. I would recommend that you file a service request to MySupport to seek for workaround from Altera. - Altera_Forum
--- Quote Start --- Hi Wen, This is a QII internal error. I would recommend that you file a service request to MySupport to seek for workaround from Altera. --- Quote End --- Thanks Tiny007, I will . :( Cheers - Altera_Forum
--- Quote Start --- Thanks Tiny007, I will . :( Cheers --- Quote End --- I install all over again and now it seem to work properly. Lets see how it works using it. Fingers cross!!! :p
