I don't find document defined below pin location
1) I don't find document defined below pin location. I don't see this information from pin connection guide line and adc convert ug
ADC[1..2]IN[1..16]; ADC_VREF; ANAIN[1] ; ANAIN[2]
2) what's the difference between ADC[1..2]IN[1..16] and ANAIN[1]?
Hi Xiaoqiang
For Q1, if we refer to Table 6 of https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/pcg-01018.pdf
There is description for ADC[1..2]IN[1..16], ANAIN[1], ANAIN[2] and ADC_VREF.
For Q2, Max10 devices support up to 18 channels for analog measurement: 16 dual function channels and two dedicated analog input channels in dual ADC devices.
ANAIN[1] is the dedicated single-ended analog input pin for ADC1 while ANAIN[2] is for ADC2.
Whereas ADC[1..2]IN[1..16] are the multi-purpose pins that support single-ended analog input. When they are not used as analog input pins, these pins can be used as any other digital I/O pins.
Eng Wei
- EngWei_O_Intel
Hi Xiaoqiang
Eng Wei
- EngWei_O_Intel
Hi Xiaoqiang
We do not receive any response from you to the previous answer that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
