14 years agoI cant work this out!
This is to adjust volume of incoming audio samples by just multiplying by a constant value (SW). I wanted to be able to control the volume value with the switches on the DE2 but i get no sound at all...
14 years agoYou could try registering your signals and then use signal tap to check your circuits logic. If it works with registers then it is probably a timing issue. If it still isn't working you should be able to see where your errors are, like switches not working correctly.
