I can't program the POF file via JTAG for the 10M02DCV36. I can program the sof file, and I can read the UserCode of the device. I can also verify the checksum after I program the SOF file.
I also tried to run the jam file. I got the following output fpr the sof file:
c:\intelFPGA_lite\18.1>quartus\bin64\quartus_jli.exe -aConfigure -i output_files\sof_program.jam
Info: *******************************************************************
Info: Running Quartus Prime Jam Tools
Info: Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Wed May 01 20:00:22 2019
Info: Command: quartus_jli -a Configure -i output_files\sof_program.jam
NOTE "CREATOR" = "QUARTUS PRIME JAM COMPOSER 18.1"
NOTE "DATE" = "2019/05/01"
NOTE "DEVICE" = "10M02DC"
NOTE "NEED_FREQUENCY_CONTROL" = "0"
NOTE "FILE" = "USI_ULTRA.sof"
NOTE "TARGET" = "1"
NOTE "IDCODE" = "031010DD"
NOTE "USERCODE" = "000697A5"
NOTE "CHECKSUM" = "000697A5"
NOTE "SAVE_DATA" = "DEVICE_DATA"
NOTE "SAVE_DATA_VARIABLES" = "V0, A12, A13, A25, A42, A93, A43, A92, A94, A95, A105, A109, A111"
NOTE "STAPL_VERSION" = "JESD71"
NOTE "JAM_VERSION" = "2.0"
NOTE "ALG_VERSION" = "68"
Info: Quartus Prime Jam Tools was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 4261 megabytes
Info: Processing ended: Wed May 01 20:00:23 2019
Info: Elapsed time: 00:00:01
Info: Total CPU time (on all processors): 00:00:00
- CalvinJoaz_P_Intel
Contributor
Hi Rob, These error messages could displayed because your design is using too many logic resources that is actually too large to fit in your device. What device you're using? Thank you.- RAlac
I'm using the 10M02DCV36. The following is my compilation report. It's a fairly simple design.
Flow Status Successful - Wed May 01 19:54:03 2019
Quartus Prime Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
Revision Name USI_ULTRA
Top-level Entity Name USI_ULTRA
Family MAX 10
Device 10M02DCV36I7G
Timing Models Final
Total logic elements 345 / 2,304 ( 15 % )
Total registers 213
Total pins 18 / 27 ( 67 % )
Total virtual pins 0
Total memory bits 0 / 110,592 ( 0 % )
Embedded Multiplier 9-bit elements 0 / 32 ( 0 % )
Total PLLs 1 / 1 ( 100 % )
UFM blocks 0 / 1 ( 0 % )
ADC blocks 0
- RRomano001
Contributor
Hi RAlac, can I suggest try an old version of programmer?
I experience same trouble and release 15.0 programmed successfully MAX 10 devices.
I am using Linux, but same version don't program .pof
- RAlac
And I got the following output for pof file:
c:\intelFPGA_lite\18.1>quartus\bin64\quartus_jli.exe -aProgram -c1 output_files\USI_ULTRA.jam
Info: Processing started: Wed May 01 20:01:33 2019
Info: Command: quartus_jli -a Program -c 1 output_files\USI_ULTRA.jam
Device #1 IDCODE is 031010DD
configuring SRAM device(s)...
No SLD hub
No SLD node
Unrecognized device
Exit code = 6... Unrecognized device
Error: Quartus Prime Jam Tools was unsuccessful. 0 errors, 0 warnings
Error: Peak virtual memory: 4262 megabytes
Error: Processing ended: Wed May 01 20:01:34 2019
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:00
