I can't program the POF file via JTAG for the 10M02DCV36. I can program the sof file, and I can read the UserCode of the device. I can also verify the checksum after I program the SOF file.
I'm using the 10M02DCV36. The following is my compilation report. It's a fairly simple design.
Flow Status Successful - Wed May 01 19:54:03 2019
Quartus Prime Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
Revision Name USI_ULTRA
Top-level Entity Name USI_ULTRA
Family MAX 10
Device 10M02DCV36I7G
Timing Models Final
Total logic elements 345 / 2,304 ( 15 % )
Total registers 213
Total pins 18 / 27 ( 67 % )
Total virtual pins 0
Total memory bits 0 / 110,592 ( 0 % )
Embedded Multiplier 9-bit elements 0 / 32 ( 0 % )
Total PLLs 1 / 1 ( 100 % )
UFM blocks 0 / 1 ( 0 % )
ADC blocks 0
- RRomano0017 years ago
Contributor
Hi RAlac, can I suggest try an old version of programmer?
I experience same trouble and release 15.0 programmed successfully MAX 10 devices.
I am using Linux, but same version don't program .pof
