15 years ago
I can't program...
I come back with another error.
Before today, I could program my EPM3064AL44-10N. But since today, I haven't programed it....
I didn't change the electronic hardware
I made a special board to program my CPLD (maybe it's the electronic around the cpld...). Nothing change.
The compile is allrigth, but when I want program I have this error message :
--- Quote Start ---
Error: JTAG Server can't access selected programming hardware
Error: Operation failed
Info: Ended Programmer operation at Wed Nov 24 22:53:06 2010
Info: Started Programmer operation at Wed Nov 24 22:53:02 2010
--- Quote End ---
I don't really understand about the first error (the second, ok I understand it ^^).
I tested the Terasic Blaster usb : when I click on the hardware device, the terasic blaster flashes once when I leave this windows, it flashes twice. When I see in the pc system, I see my Terasic blaster is connected. When I disconnect my terasic blaster, I see everywhere (pc + hardware device) that there isn't a terasic blaster was connected.
On my programmable board, I changed the cpld three times...
I verified my connections twice...
Oh... to finish, I changed the terasic blaster too...the first heat when I connected it to usb. I verify the PC usb with a usb key, and it's ok.
Thank you
    I wondered whether that really could be the problem ...
    I have seen that on the latest boards (and perhaps earlier as well) Altera puts a termination circuit on the Tck signal (at the last pin in that net), although they mark it DNI (Do Not Insert). But I always put that termination. Perhaps the 1k pull down just helps enough.
    Who supplies the 3.3V to the EPM, not the cable I presume?
    Josyb => ok, but my schema worked before... before ^^
    Finally, with a third PC, I can programm but currently, without changing nothing... Tomorrow I will test with the two first PC.
    yes, I tried it : no device detected with one PC (windows vista 32bits) and the other one (windows xp) it said
    --- Quote Start ---
    error : JTAG chain problem detected
    error : no device detected
    error : the tdo connection to the download cable might bo shorted to VCC or is an open circuit
    error : the tck and TMS connection to the last device might have problem
    --- Quote End ---
    I changed the cpld 6 times.... and I tried with the bytebaslterII too (parallel port) with the XP PC. Impossible programming...
