9 years agoI cant find any mistake but my compiler says its a mistake
Dear all, Please help me out her. counter <= counter + '1'; this is my instruction this is my error. So what is the mistake in it? Error (10327): VHDL error at led_blink.vh...
8 years agolibrary ieee;
use ieee.std_logic_1164.all;
use IEEE.numeric_std.all;
entity cnt is
port
clk : in std_logic;
enable : in std_logic;
sr_out : out std_logic_vector(3 downto 0);
sr_in : in std_logic
end entity;
architecture rtl of cnt is
-- Build an array type for the shift register
signal sr: unsigned(3 downto 0);
-- Declare the shift register signal
begin
process (clk)
begin
if (rising_edge(clk)) then
if (enable = '1') then
sr<=sr+1;
end if;
end if;
end process;
-- Capture the data from the last stage, before it is lost
sr_out <= std_logic_vector(sr);
end rtl;
You should also add a reset condition to give your sr signal a default value.
