9 years agoI can not able to configure fpga to quartus
Dear All, I am sasi, Trying to program the fpga , But I can not able to do it.I configer the jtag usb blaster ii, they are perfectly fine , the only problem is I can not see any hardware config...
9 years agoHi sasi1922,
What is the error message from the Quartus message log? The screen shots does not show the actual message log. Which board are you using? I can see that you have auto-detect the devices in the JTAG chain which show 2 devices (SOCHPS and 5CSEMA). Since the programmer has auto-detect these 2 devices (SOCHPS and 5CSEMA) then you just need to add the .sof file into the 5CSEMA device. You should right click at the 5CSEMA device and choose Change File (not Add file). Then select the correct .sof file for the 5CSEMA device. Regards, mayui@neko (This message was posted on behalf of Intel Corporation)
