CHatz
7 years agoI am using the same JTAG connector to test the FPGA with System Console and to monitor signals with Signal Tap analyzer.
I cannot program the FPGA using signal tap when System Console is open. The other issue I am having is that Signal Tap analyzer won't trigger when I am accessing registers fro System Console (both t...
Abe
7 years agoWhich board are you using and what is the type of download cable - USB Blaster II / USB blaster with JTAG header (9-pin). Does the board in question use micro-USB port or 9-pin JTAG connector for FPGA configuration? Generally, if the board uses JTAG headers, then you may have two headers, one for configuration and another for Signal-Tap and system console ( UART i/f ,etc).
