8 years agoI am not getting expected response in Modelsim
Dear all,
Could someone please have a look at my code and say what is wrong in it. entity pinconfig is port( pins :in std_logic_vector (13 downto 0):="00000000000000"; signalsin :inout std_logic_vector (35 downto 0); signalsout :inout std_logic_vector (35 downto 0) ); end pinconfig; architecture behav of pinconfig is component iobuffer PORT ( datain : IN STD_LOGIC_VECTOR (35 DOWNTO 0); oe : IN STD_LOGIC_VECTOR (35 DOWNTO 0); dataio : INOUT STD_LOGIC_VECTOR (35 DOWNTO 0); dataout : OUT STD_LOGIC_VECTOR (35 DOWNTO 0) ); end component; type c is array (0 to 35, 0 to 2) of integer range 0 to 35; signal config : c := ((0,0,1),(1,1,1),(2,2,1),(3,3,0),(4,4,3),(5,5,0),(6,6,3),(7,7,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3), (12,12,3),(13,13,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,18,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3), (24,24,3),(25,25,3),(26,26,3),(27,27,0),(28,28,3),(29,29,0),(30,30,0),(31,31,0),(32,32,0),(33,33,0),(34,34,0),(35,35,3)); --signal config : c := --((0,27,3),(1,29,3),(2,31,3),(3,5,0),(4,4,3),(5,4,0),(6,13,3),(7,18,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3), --(12,12,3),(13,6,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,7,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3), --(24,24,3),(25,25,3),(26,26,3),(27,0,0),(28,28,3),(29,1,0),(30,33,0),(31,2,0),(32,34,0),(33,3,0),(34,35,0),(35,32,3)); --config(x,x,0) = out (fpga => gpio) --config(x,x,1) = in (fpga <= gpio) --config(x,x,2) = constant low (pin) --config(x,x,3) = high-Z (pin) signal temp: std_logic_vector (35 downto 0); I Used 2 different pin configurations. Both failed thanks11 Replies
You dont say what the problem is?
You Didnt post the whole code? your picture is far too small. Not much we can say until you fix the above.
