8 years agoI am not getting expected response in Modelsim
Dear all,
Could someone please have a look at my code and say what is wrong in it. entity pinconfig is port( pins :in std_logic_vector (13 downto 0):="00000000000000"; signalsin :inout std_logic_vector (35 downto 0); signalsout :inout std_logic_vector (35 downto 0) ); end pinconfig; architecture behav of pinconfig is component iobuffer PORT ( datain : IN STD_LOGIC_VECTOR (35 DOWNTO 0); oe : IN STD_LOGIC_VECTOR (35 DOWNTO 0); dataio : INOUT STD_LOGIC_VECTOR (35 DOWNTO 0); dataout : OUT STD_LOGIC_VECTOR (35 DOWNTO 0) ); end component; type c is array (0 to 35, 0 to 2) of integer range 0 to 35; signal config : c := ((0,0,1),(1,1,1),(2,2,1),(3,3,0),(4,4,3),(5,5,0),(6,6,3),(7,7,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3), (12,12,3),(13,13,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,18,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3), (24,24,3),(25,25,3),(26,26,3),(27,27,0),(28,28,3),(29,29,0),(30,30,0),(31,31,0),(32,32,0),(33,33,0),(34,34,0),(35,35,3)); --signal config : c := --((0,27,3),(1,29,3),(2,31,3),(3,5,0),(4,4,3),(5,4,0),(6,13,3),(7,18,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3), --(12,12,3),(13,6,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,7,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3), --(24,24,3),(25,25,3),(26,26,3),(27,0,0),(28,28,3),(29,1,0),(30,33,0),(31,2,0),(32,34,0),(33,3,0),(34,35,0),(35,32,3)); --config(x,x,0) = out (fpga => gpio) --config(x,x,1) = in (fpga <= gpio) --config(x,x,2) = constant low (pin) --config(x,x,3) = high-Z (pin) signal temp: std_logic_vector (35 downto 0); I Used 2 different pin configurations. Both failed thanks11 Replies
Hai Raj,
I am not writing test bench . I directly compile through Quartus RTL Simulation. - Altera_Forum
Hi Sasi,
Your simulation is not acting as you would expect from your source code. This is a clear hint for missing signals in a process sensitivity list. After a brief look on your posted code, your second and third process is missing "case_config" in its process sensitivity list. If you have a look at the synthesis report, you should find a warning about missing signals in the sensitivity list as well. Best, Jusuf - Altera_Forum
Are you trying to tell that bidirectional pin's are not responding after forcing input to it? If yes, in test bench while changing config you should set the bidirectional pins to noforce. can you post a portion of test bench code? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Try to add your screenshots in a picture format that isn't reduced to unreadable garbage by the board software, e.g. .png. Check the picture after posting, retry if necessary.
I wrote complete program in Quartus II and Here I compile and.. Later I used tools ..there I have option RTL simulation this means Modelsim.
Did you write a testbench? how are you driving the design?
--config(x,x,1) = in (fpga <= gpio) --config(x,x,2) = constant low (pin) --config(x,x,3) = high-Z (pin) these are the config rules I used. And this program is pinconfiguration of the FPGA TO GPIO and GPIO TO FPGA. ALTBIO (Bidirectional buffer) I used here. And I am trying to develop the module for FPGA to configure faster and run faster. But I could not able to see expected output in model sim. - Altera_Forum
Picture is still too small
You didnt say what this code is meant to do, or whats wrong? Commenting on what code you did post - it is pretty bad - big arrays full of constants with no explanations of what they are. Especially when you didnt say what the code does or whats wrong with the code. - Altera_Forum
What ever the configuration I use, I am not getting any response in modelsim waves . I compiled with zero errors in Quartus II
library IEEE;
use IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; entity pinconfig is port( pins :in std_logic_vector (13 downto 0):="00000000000000"; signalsin :inout std_logic_vector (35 downto 0); signalsout :inout std_logic_vector (35 downto 0) ); end pinconfig; architecture behav of pinconfig is component iobuffer PORT ( datain : IN STD_LOGIC_VECTOR (35 DOWNTO 0); oe : IN STD_LOGIC_VECTOR (35 DOWNTO 0); dataio : INOUT STD_LOGIC_VECTOR (35 DOWNTO 0); dataout : OUT STD_LOGIC_VECTOR (35 DOWNTO 0) ); end component; type c is array (0 to 35, 0 to 2) of integer range 0 to 35; signal config : c := ((0,27,0),(1,29,0),(2,31,0),(3,5,0),(4,4,3),(5,4,0),(6,13,3),(7,18,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3), (12,12,3),(13,6,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,7,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3), (24,24,3),(25,25,3),(26,26,3),(27,0,0),(28,28,3),(29,1,0),(30,33,0),(31,2,0),(32,34,0),(33,3,0),(34,35,0),(35,32,3)); --signal config : c := --((0,0,0),(1,1,0),(2,2,0),(3,3,0),(4,4,3),(5,5,0),(6,6,3),(7,7,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3), --(12,12,3),(13,13,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,18,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3), --(24,24,3),(25,25,3),(26,26,3),(27,27,0),(28,28,3),(29,29,0),(30,30,0),(31,31,0),(32,32,0),(33,33,0),(34,34,0),(35,35,3)); --signal config : c := --((0,27,3),(1,29,3),(2,31,3),(3,5,0),(4,4,3),(5,4,0),(6,13,3),(7,18,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3), --(12,12,3),(13,6,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,7,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3), --(24,24,3),(25,25,3),(26,26,3),(27,0,0),(28,28,3),(29,1,0),(30,33,0),(31,2,0),(32,34,0),(33,3,0),(34,35,0),(35,32,3)); --config(x,x,0) = out (fpga => gpio) --config(x,x,1) = in (fpga <= gpio) --config(x,x,2) = constant low (pin) --config(x,x,3) = high-Z (pin) signal temp: std_logic_vector (35 downto 0); begin process (pins) begin --pins(13 downto 8) = mapped to --pins(7 downto 2) = mapped from --pins(1 downto 0) = out, in or high-Z config(to_integer(unsigned(pins(13 downto 8))),1) <= to_integer(unsigned(pins(7 downto 2))); config(to_integer(unsigned(pins(13 downto 8))),2) <= to_integer(unsigned(pins(1 downto 0))); end process; process (signalsin, signalsout) begin case config(0,2) is when 0 => temp(config(0,0)) <= signalsin(config(0,1)); when 1 => temp(config(0,1)) <= signalsout(config(0,0)); when others => end case; case config(1,2) is when 0 => temp(config(1,0)) <= signalsin(config(1,1)); when 1 => temp(config(1,1)) <= signalsout(config(1,0)); when others => end case; case config(2,2) is when 0 => temp(config(2,0)) <= signalsin(config(2,1)); when 1 => temp(config(2,1)) <= signalsout(config(2,0)); when others => end case; case config(3,2) is when 0 => temp(config(3,0)) <= signalsin(config(3,1)); when 1 => temp(config(3,1)) <= signalsout(config(3,0)); when others => end case; case config(4,2) is when 0 => temp(config(4,0)) <= signalsin(config(4,1)); when 1 => temp(config(4,1)) <= signalsout(config(4,0)); when others => end case;--here i have to write code for all 36bpins, but i cannot write a reply to you more than 10000 when others => end case; end process; process (temp) begin case config(0,2) is when 0 => signalsout(config(0,0)) <= temp(config(0,0)); when 1 => signalsin(config(0,1)) <= temp(config(0,1)); when 2 => signalsout(config(0,0)) <= '0'; when others => signalsout(config(0,0)) <= 'Z'; end case;case config(1,2) is when 0 => signalsout(config(1,0)) <= temp(config(1,0)); when 1 => signalsin(config(1,1)) <= temp(config(1,1)); when 2 => signalsout(config(1,0)) <= '0'; when others => signalsout(config(1,0)) <= 'Z'; end case;case config(2,2) is when 0 => signalsout(config(2,0)) <= temp(config(2,0)); when 1 => signalsin(config(2,1)) <= temp(config(2,1)); when 2 => signalsout(config(2,0)) <= '0'; when others => signalsout(config(2,0)) <= 'Z'; end case;case config(3,2) is when 0 => signalsout(config(3,0)) <= temp(config(3,0)); when 1 => signalsin(config(3,1)) <= temp(config(3,1)); when 2 => signalsout(config(3,0)) <= '0'; when others => signalsout(config(3,0)) <= 'Z'; end case;case config(4,2) is when 0 => signalsout(config(4,0)) <= temp(config(4,0)); when 1 => signalsin(config(4,1)) <= temp(config(4,1)); when 2 => signalsout(config(4,0)) <= '0'; when others => signalsout(config(4,0)) <= 'Z'; --here i have to write code for all 36bpins, but i cannot write a reply to you more than 10000
when others => signalsout(config(35,0)) <= 'Z'; end case; end process; end behav; Have a loot and help me
