CSegu
7 years agoI am not able to program epcq128a with .jic file via jtag .
I noticed that I use ethernet blaster at JTAG frequecny 10kHz downloading of .jic file is succesdful. Can I reduce JTAG frequency of USB BLASTER2? Attached is also a schematic showing the wiring bet...
CSegu
7 years agoHi Nooraini,
I am able to program EPCQ128A with.jic via JTAG using ethernet bluster. No download failure occurs. The issue is that when I turn off the FPGA board and re-power it up again, it is seems for some reason that the FPGA is not being programmed automatically from EPCQ128A device.
What is the procedure for FPGA to be programmed automatically on power-up from EPCQ128A device?
When I download .sof file using quartus programmer it runs automatically.
Thank you.
Clive
