16 years agoHSMC JTAG chain
Hello, I am using Stratix III with data conversion card. I realized that HSMA_BYPASS has to be set 1 to enable the port A. This mean that JTAG setting should be set at '1100' in sw 1; "...
16 years agoReferring to your original question:
--- Quote Start --- I am using Stratix III with data conversion card. I realized that HSMA_BYPASS has to be set 1 to enable the port A. --- Quote End --- This is wrong. Read the manual strictly. Yes, I'm talking of JTAG control DIP switch. The setting HSMA_BYPASS = 1 is only correct, if a JTAG capable device is connected at the HSMA port. With no JTAG device at HSMA port, you get "can't access JTAG chain", as you already tried.
