16 years agoHSMC JTAG chain
Hello, I am using Stratix III with data conversion card. I realized that HSMA_BYPASS has to be set 1 to enable the port A. This mean that JTAG setting should be set at '1100' in sw 1; "...
16 years agoI'm sorry, but can you specify the instruction?
"the switch is required to enable jtag function on hsmc connectors" when you said 'the switch', are you referring to JTAG control DIP switch or MAX II control DIP switch? I am not really sure what "Embedded USB Blaster Stratix III device + HSMC Port A" mean on JTAG setting table. once again, thank you for sharing your knowledge.
