16 years agoHSMC JTAG chain
Hello, I am using Stratix III with data conversion card. I realized that HSMA_BYPASS has to be set 1 to enable the port A. This mean that JTAG setting should be set at '1100' in sw 1; "...
16 years ago --- Quote Start --- In order to use HSMC Port A, shouldn't JTAG setting be '1100'? --- Quote End --- No. --- Quote Start --- How do you enable the HSMC Port A or HSMC Port B? --- Quote End --- It doesn't need to be enabled. The switch is required to enable jtag function on hsmc connectors, not to enable HSMC ports itself. JTAG can be used only with a HSMC card that's supporting it.
