16 years agoHSMC JTAG chain
Hello, I am using Stratix III with data conversion card. I realized that HSMA_BYPASS has to be set 1 to enable the port A. This mean that JTAG setting should be set at '1100' in sw 1; "...
16 years agoIf the JTAG chain is operational in '1000' setting, the installed HSMC board is most likely not using the JTAG interface at all. Is it said to use it?
P.S.: If you're possibly refering to the Terasic Data Conversion board, the manual doesn't even mention JTAG and it has no components, that could be accessed through JTAG.
