12 years agoHPS2FPGA bridge throughput
Hi everybody, I am currently playing around with the Cyclone V SoC Development board. I have a QSys system running resembling the Golden system reference design apart from the fact that the h...
12 years agoSome memcpy implementations use 32-bit copy operations, and if the CPU has a data cache it will cause burst transfers, but it is still slower than a DMA solution as I'd say you'd need about 10 CPU cycles for each 32-bit transfer (maybe a Nios II guru will correct this figure).
If the source or destination isn't 32-bit aligned, memcpy will most probably revert to 8-bit transfers anyway.
