9 years agoHPS Configuration in QSys: Why is hps_io exported?
When I configure the HPS in QSys (Quartus Prime 16.0), I can determine the Pin muxing in the "Peripheral Pins" section. In the "Peripherals Mux Table" on the bottom, I can see how the various control...
9 years agoHi, thanks for your reply but I guess you're wrong when you say that the hps pin location assignments are necessary so that the qsys design can be reused in different Cyclone V SoC packages. It seems to me that the pin location assignments for hps-pins are actually ignored. I have tested the following:
- When I delete the pin location assignments of an ordinary FPGA pin, the fitter will give me warnings about missing location assignments.
- When I delete the pin location assignments of I2C0 pins, the fitter does not complain about locations, it just complains about missing drive strength and slew rate.
