HPS access to SDM for internal TDS readings
- 3 years ago
yes I got it to work on stratix 10 with linux 5.15.30-lts and uboot 2022.01, ATF 2.6.1
The process is to enable the HWMON in the defconfig of the kernel (CONFIG_SENSORS_SOC64=y) and add a new node to the device tree that contains the labels and register address of the ADC channels that is then readout by the SDM.
look at 5.15.70-lts for some documentation and an example of adding these nodes to the device tree. You may also look at the patches made to this tag for the HWMON and apply them yourself if needed.
After doing that, booting into HPS in HPS first mode without loading any bitstreams, you can read the voltages and the die temperature with a system call at " /sys/class/hwmon/hwmon0/[<name>_label or <name>_input> "
the values are already multiplied by 1000 in the driver.
Hi
It is right, the mailbox is required to access the SDM.
The mailbox will act as an interface to the SDM as the SDM is located in the FPGA Fabric.
Sorry that the SDM is designed this way.
Jingyang, Teh
