How well FPGA adjust delays based on .sdc
- 2 years ago
Perhaps sstrell could help to clarify more on your first question.
Anyhow, we uses one of the two methods in deriving the input and output constraints for the SS.
From what I see in the diagram, you may consider using the system-centric method.By specifying the appropriate clock waveform using the -waveform option, you can effectively align the clock edges to accommodate the data transfer requirements. Whether you choose center alignment or edge alignment depends on your specific design needs.
You may checkout the "Clock and Data Relationship" section in AN433 and below screenshot.
Richard Tan
If you have any further questions or concerns, please don't hesitate to let us know.
Richard Tan
- paw_932 years ago
Hi Richard,
Thank you for your answer. Yes, that answer was helpful. From that I conclude that Intel prefers to use -waveform option instead of -clock_fall in that specific scenarios.
Have a nice day!
