paw_93
2 years agoHow well FPGA adjust delays based on .sdc
Hi, I have a question regarding the way the sdc timing constraints affect the design. Imagine a situation where we have a source synchronous design (both directions). FPGA drives flip-flop on the ...
- 2 years ago
Perhaps sstrell could help to clarify more on your first question.
Anyhow, we uses one of the two methods in deriving the input and output constraints for the SS.
From what I see in the diagram, you may consider using the system-centric method.By specifying the appropriate clock waveform using the -waveform option, you can effectively align the clock edges to accommodate the data transfer requirements. Whether you choose center alignment or edge alignment depends on your specific design needs.
You may checkout the "Clock and Data Relationship" section in AN433 and below screenshot.
Richard Tan
RichardT_altera
2 years agoDropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
