14 years agoHow to write Transfer function using QUARTUS II
Sir
1. Would anyone like to guide me to pen down a Transfer function [e.g (a2S2+a1S+a0)/(b2S2+b1S+b0) ] in Altera Quartus II 9.1 using Block diagram/ Schematic file? 2. How to implement derivation and integration in Quartus II Actually I want to implement a PID controller and Lag-lead Controller with regards Kingsuk3 Replies
Sir,
thank you for your kind response I used HDL workflow Advisor (Matlab 2012a) to generate HDL code there I can easily convert a transfer function into HDL but in Quartus I'm facing this problem. @james bonanno (http://www.alteraforum.com/forum/member.php?u=23400): Sir, yes I'm little bit confuse due to the following reasons 1. In Matlab I successfully generate some code and check with co-simulation result but can not find out how to download that code into FPGA kit (Altera Cyclone EP1C12Q240C8) 2. I want input(/output) to(/from) some specific pins but can not solve this problem. (actually I'm facing this problem with Altera also when a signal requires more than one bit say a 8bit adder output) Hence I switch over to Altera Quartus II(vary much new to Altera Quartus) would you like to give me a way to solve it With Regards Kingsuk My System: os: Windows xp (sp2) 32bit Matlab : 2012a (32 bit) Altera Quartus II 11.0sp1 Web Edition (32bit) Modelsim 10.0c SE FPGA kit : Altera Cyclone EP1C12Q240C8 - Altera_Forum
I did upload a whitepaper in the discussion thread around PID controllers:
http://www.alteraforum.com/forum/showthread.php?t=33192&highlight=pid+controller Additionally, the question that you ask is confusing. HDL design (VHDL or System Verilog) captures a hardware design; the hardware design being reflective of whatever algorithm that you are implementing. So there are numerous technology steps: 1. Matlab/Simulink/Python/C model of your controller + plant or general dynamical system model 2. Transform to digital domain of the controller (say bilinear Z transform) 3. General digital architecture planning for the controller 4. Fixed point mathematics precision (say 16 or 24 bits) 5. HDL Coding 6. HDL Testbench 7. Refinement 8. System Testing - Altera_Forum
That's not a particularly a Quartus problem. Your question refers to digital signal processing basics. How s-domain transfer functions translate to z-domain, how z-domain functions are implemented as differential equations. Finally how to choose a suitable number format (preferably fixed point), how to code it in HDL.
IMHO, a good text book covering all aspects is digital signal processing with fpga by Maeyer-Baese. P.S.: There are also special high-level tools like Altera DSP builder (based on Matlab). I think, you should refer to generic HDL signal processing.
