14 years agoHow to write Transfer function using QUARTUS II
Sir 1. Would anyone like to guide me to pen down a Transfer function [e.g (a2S2+a1S+a0)/(b2S2+b1S+b0) ] in Altera Quartus II 9.1 using Block diagram/ Schematic file? 2. How to ...
14 years agoSir,
thank you for your kind response I used HDL workflow Advisor (Matlab 2012a) to generate HDL code there I can easily convert a transfer function into HDL but in Quartus I'm facing this problem. @james bonanno (http://www.alteraforum.com/forum/member.php?u=23400): Sir, yes I'm little bit confuse due to the following reasons 1. In Matlab I successfully generate some code and check with co-simulation result but can not find out how to download that code into FPGA kit (Altera Cyclone EP1C12Q240C8) 2. I want input(/output) to(/from) some specific pins but can not solve this problem. (actually I'm facing this problem with Altera also when a signal requires more than one bit say a 8bit adder output) Hence I switch over to Altera Quartus II(vary much new to Altera Quartus) would you like to give me a way to solve it With Regards Kingsuk My System: os: Windows xp (sp2) 32bit Matlab : 2012a (32 bit) Altera Quartus II 11.0sp1 Web Edition (32bit) Modelsim 10.0c SE FPGA kit : Altera Cyclone EP1C12Q240C8
