12 years agoHow to write data from PC to Flash memory (not using de0 control panel)
Any insight on the title problem is greatly appreciated.
I want to load data (e.g. image data) from PC into the memory and then later use that memory when I initiate start signal.2 Replies
So it seems to me I have to make a UART controller in the FPGA?
On the DE0 if you put a Serial Flash Loader or a Parallel Flash Loader image in the FPGA you can directly access the EPCS flash from Quartus Programmer.
