16 years agoHow to Write Configuration and Program Data to EPCS Directly Not via FPGA
Hi, I'm looking for a tutorial or how-to on loading configuration and program data into an EPCS device connected to a Cyclone III device. I want to program using a download cable to the EP...
16 years agoLook at the instructions for putting a JIC together (SOF + any hex files). Typically, this requires some additional steps:
1. Modify the bootloader to locate the ELF at a fixed address inside the SPI flash (EPCS). 2. Use elf2flash to generate a .flash file. 3. Relocate/shift the addresses in this .flash file. - It's really just an SREC. 4. Convert this SREC to a HEX file using objcopy or other capable program of your choice. I won't provide further details as there are other, more detailed instructions available on this forum and, I believe, as solutions on Altera. I recommend using Altera's site search for stuff like this...it includes forum and Wiki results, along with official Altera solutions, documentation and collateral. Regards, --slacker
