14 years ago
how to watch the rx_datain , the rx_errdetect ports ?
Hi
I am a beginner, and am working on Stratix IV board.
How to watch the rx_datain , the rx_errdetect ports ?
I checked Stratix GX device handbook and the forum as well, and there ARE a lot of information about the ports. However, I still do not know how to check or watch the signals(ports).
Should I allocate the signals to some FPGA balls and use a oscilloscope ?
Thanks a lot
    you should be able to signaltap rx_errdetect, however rx_datain is a high-speed serial port and can't be tapped with signaltap (you will get an error or internal error). you should instead tap rx_dataout, which is the deserialized parallel output (think shift register)
    If these signal are not input/output of your top-level entity, I advise you to use SignalTap tool of Quartus, really simple and efficient.
    - Yes, I often do this and solved lots of problems.
