14 years agohow to watch the rx_datain , the rx_errdetect ports ?
Hi I am a beginner, and am working on Stratix IV board. How to watch the rx_datain , the rx_errdetect ports ? I checked Stratix GX device handbook and the forum as well, and there ARE a l...
14 years agoyou should be able to signaltap rx_errdetect, however rx_datain is a high-speed serial port and can't be tapped with signaltap (you will get an error or internal error). you should instead tap rx_dataout, which is the deserialized parallel output (think shift register)
