17 years agohow to view clock in signal tap analyzer?
I have problem of viewing clock in Signal Tap Analyzer ..... can any one suggest how to view clock?
17 years agoIs there a reason why you want to see the clock? Do you suspect the clock to be problematic? There is typically no point in seeing the clock. The samples captured in SignalTap are sampled on the clock. So each sample is a clock edge. If the clock isn't running, you won't get any samples and signaltap will just hang waiting for samples when you click the capture button.
Jake
