12 years agoHow to using SDI megacore function - Cyclone V GT FPGA Development Kit
Hi all,
i have a Cyclone V GT FPGA Development Kit, Set up the hardware by connecting SDI HSMC daughter card into HSMC port B i created a simple example in order to display from Test Pattern IP channel to SDI HSMC card, standard SDI 1920x1080p@60 >>this is figure diagram: (https://lh5.googleusercontent.com/-s4hvupaoyfq/u3okqsc8e2i/aaaaaaaaek0/eioyjf9yke4/w729-h345-no/sopc.png) >> (https://lh4.googleusercontent.com/-ggaqmp8ox58/u3onzvfut-i/aaaaaaaaemu/x0_uescb8vg/w843-h585-no/detail.png)this is figure diagram: (https://lh5.googleusercontent.com/-s4hvupaoyfq/u3okqsc8e2i/aaaaaaaaek0/eioyjf9yke4/w729-h345-no/sopc.png) (detail) (https://lh4.googleusercontent.com/-ggaqmp8ox58/u3onzvfut-i/aaaaaaaaemu/x0_uescb8vg/w843-h585-no/detail.png) Parameter + test pattern generator Width : 1920 Heigh : 1080 Color space : YCbCr Output Format : 4:2:2 Color plane configuration : Parallel + clock video output Using template : SDI 1080p60 This is project file + SDI HSMC Card PLL active, 27Mhz reference sdi megacore funtion- Protocol options + video standard : HD-SDI + interface setting: Bidirectional - Transceiver Options + Generate transceiver and protocol blocks But this example not running. Please help me how to using SDI megacore function !! Download Project File:
