taleunicorn's avatar
taleunicorn
4 years ago
How to use WYSIWYG primitive cycloneive_crcblock in EP4CE55F23I7?
Recently, I want to analyze the SEU flip in the CRAM of the cyclone4 chip. I instantiated the cycloneive_crcblock primitive in my project, and the whole project synthesis successfully. But when I want to grab these input and output signals (shiftnld, ldsrc, crcerror, regout) in primitives in SingalTap, I find that these signals are not found at all. However I can find the signal named after this primitive block instantiation in SignalTap. For example, I named this primitive instantiation 'Cramdetection', and I can find a single bit signal called 'Cramdetection.
That's all my questions, thanks all.
  • ShengN_altera's avatar
    ShengN_altera
    Since there are no further feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
    ShengN_altera
    May I know any further update or concern?
    Sheng
    ShengN_altera
    Go to new instance -> add nodes -> node finder -> search for * -> list and you should see all the available signals. I don't think Cramdetection is equivalent to the signal crcerror because it's just a given block name. As for user logic you may check this link https://www.macnica.co.jp/business/semiconductor/support/faqs/intel/139528/
    Sheng
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
