sung_chul
3 years agoHow to use Transceiver PHY 12 port
Hi- Everyone I'm designing a Transceiver PHY 12 port. Transceiver PHY 11 port is passed! It is composed of Transceiver PHY IP 1, Transceiver PHY PLL IP 1, Transceiver PHY Reset IP 1 So, I hav us...
Kshitij_Intel
3 years agoHi,
Can you please share the project to reproduce the issue at my end. I would like to see error message.
Which PLL(ATX, fpll, CMU) you are using when project fails?
There should not be any reason which prevents you from using 12 channels unless you are using 12 channels device with ATX or fpll. Please share the device OPN as well.
Thank you
Kshitij Goel
