11 years agoHow to use the "Debounce Operation" for a Cyclone V.
I would like to use the "Debounce Operation" for a Cyclone V GX, 5CGXFC5C6F27C7N, on a Terasic "Cyclone V GX Starter Kit." The starter kit uses a Schmitt-Trigger buffer on the board to reduce bounce ...
11 years agoGalfonz,
Thank you for the quick reply. I'll need some more details to be able to implement as almost everything I have ever done with an Altera FPGA has been done via Quartus II. What "software" are you referring to when you say, " You will need to set it in software?" Can you give me some key words so I can do some research on what this "software" is and how to use it? Much thanks, Al
