15 years agoHow to use the DCFIFO?
Hello i used the megawizard to instantiate a DCFIFO but it seems i can't write anything to the fifo.. my usedw never changes
Anyone has a verilog example of a code that is working??? I tried to let wrreq always at 1 and wrclck changes when i need to write something16 Replies
My assumption is that your fifo gets full.
When the fpga starts and soon after reset, you are writing into the fifo without reading thus it gets full and the word count will increase from 0 to 128. When 128 the word count cannot represent 128 and rolls back to zero unless you have one extra bit on your word count. The best way is to simulate your design or trigger the signaltap when fifo words is say half (bit[5] '0' => '1') - Altera_Forum
Sorry can you explain better?
it could be just overflowing with word counter rolled over
several issues but I see that when your counter is == 10 the word count may not coincide with wordcount[2] == 1
{count 0 ~ 10}means 10~11 words = 1010 or 1011 - Altera_Forum
Here is my wrapper. Please help!
My valid never goes to 1. My rdclk is at 50mhz (duno if that matters, i guess not)module fifowrapper( // inputs: rdclk, rstn, rdreq, // outputs: valid, q ); input rdclk; input rdreq; input rstn; reg wrclk; reg wrreq; output q; output reg valid; wire data; reg data_in; assign data = data_in; wire usedw; reg usedw_r; assign usedw = usedw_r; reg counter; always@(posedge rdclk or negedge rstn) if (~rstn) begin valid <= 0; wrreq <= 0; contador <= 0; data_in <= 0; wrclk <= 0; end else begin counter<= counter+1; // valid <= 0; // rdreq <= 1; wrreq <= 1; // wrclk <= 0; if(counter== 10) //1seg begin if(usedw_r==1) valid <= 1; counter<= 0; data_in <= data_in + 1; // wrreq <=1; // valid <= 1; end // if (usedw_r==1) // begin // valid <= 1; // end end base fifo_inst ( .data ( data ), .rdclk ( rdclk ), .rdreq ( rdreq ), .wrclk ( rdclk ), .wrreq ( wrreq ), .q ( q ), // .rdempty ( rdempty_sig ), // .rdusedw ( usedw ), .wrusedw ( usedw ) // .wrfull ( wrfull_sig ) ); endmodule
