16 years agoHow to use Shared pll in LVDS transmiter and resceiver functions
Hi, I am trying to use the shared pll function for LVDS transmiter and resceiver. AN479 says transmiter and resceiver must use the same input clock frequency. does it mean the tx_inclock of tran...
16 years agoIt seems you misunderstood the serdes functionality. Why do you connect the two clocks you mentioned?
I assume your 100MHz is the ref clock for serdes PLL(it has nothing to do with data). The PLL should then produce two clocks: At Rx: the PLL should generate 40MHz for your 20bit data processing. At tx:The PLL should generate 800MHz internally to kick serial bit stream out at 800 Mbps. This fast clk is not accessible to you, it is for serdes use.
