how to use fmc connector to drive the AD9361 board
I want to use AD-FMCCOMMS3-EBZ board to realize wireless data transmission. how to use the fmc connector to drive the AD9361 board?
- AqidAyman_Altera
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- AqidAyman_Altera
Have you got the chance to follow the suggestions from FvM? Does it solve your issue?
- FvM
I didn't look into the example project details, apparently it involves FPGA and embedded processor application parts. It should be possible to port it to Quartus and NIOS V soft processor (presume your dev kit has no hardware processor).
There are also other SDR projects using Intel FPGA, don't know if you'll find AD9361 related code. - FvM
FMC interface is provided by a number of FPGA evaluation boards. AD-FMCCOMMS3-EBZ design examples are using Xilinx boards, but as FMC pin assignment is ANSI standard, the board should also work with Intel boards that support the required features.- masato1
Thank you for your reply. How to configure AD-FMCOMMS3 via the fmc connector of cyclone 10 gx development kit board.
