LChow3
3 years agoHow to use CLOCK_50 on Cyclone II device
I like to program a simple D flip-flop with an asynchronous reset. It requires a Clock input. I'm using a Cyclone II device. Shall I use the pin CLOCK_50 as the Clock? Is there any example of how...
Nurina
3 years agoHi,
I assume you're able to write the RTL code and that you're using this development board: https://cs.colby.edu/courses/F22/cs232-labs/DE1_User_Manual.pdf
From your RTL code, you probably have an input clock signal, assign this to the PIN_L1 on Pin Planner, you may find this helpful: https://www.youtube.com/watch?v=XH4OajcYYjA
Nurina
