12 years agoHow to turn on Cyclone V LVDS 100Ohm termination in Pin Planner?
Hi, I am using Quartus-II v13.1 with the Cyclone V 5CSXFC6D6F31C8NES. I have several LVDS I/O pairs going to the LVDS interface of a high-speed ADC. One example of such an I/O pair would be pin...
11 years agoHi,
It is recommended for your to double verify if the 100Ohm termination has been enabled by run the Fitter compilation and then check the Fitter report. You may look for input pins section.
