12 years agoHow to transfer data from pc to sdram?
Hi, What program can I use to transfer data from my PC to the SDRAM or FLASH memory on the board? I am using DE0. For example I want to transfer the bit stream encoding an image file onto...
12 years agoSo, using the de0 control panel, I am trying to write some values (0 in 0, 1 in 1, 2 in 2) into the flash memory and then dump the contents to a hex file. But having some trouble, doesn't seem to be working.
